18 years agohelp: data read from not same as the *.flash file,why?
hi, i downloaded the *.flash into flash, and run the program successfully, i read the data from ext_flash in nios program, and found it's not the same as the *.flash i used, why?
18 years agohi,
my flash only included nios program(elf2flash), configuration data(sof2flash) was in epcs. when Por, the program is run in the course of nature. and then read from flash, i found that the data of flash was not the same as the *.flash(elf2flash). i don't know why.
