17 years agohelp about dvb-asi
hi; i have a little misunderstanding in dvb-asi..about the difference between mpeg ts paket (188 bytes) and tx_data (parallel 8 bit) i attach a sheme explaining my question. thanks.
17 years agoThe video interfacing standards are set by ETSI(for European DVB). If you search ETSI site you will find them but the parallel interface is too obvious anyway, just 8 bits data plus clk plus data_valid. It is indeed called SPI = synchronous Parallel Interface as opposed to the more involved ASI(Asynchrnous Serial Interface). There is also SSI(Synchronous Serial Interface) but don't know if anybody uses it.
