CShek1's avatar
CShek1
8 years ago
hello sir can u help me, i am displaying 3 digits using seven segment display, everything is done i got output(used verilog HDL code) but the problem is during power up it is reset to "000". previous values are not stored. so what is the solution
  • Tricky's avatar
    Tricky
    What are you trying to do? Why do you need to retain state after power down?​
  • CShek1's avatar
    CShek1
    k thank you for reply, but what is the solution sir.,
  • Tricky's avatar
    Tricky
    FPGAs are volatile, so state is always lost on reset
