13 years agoHDMI with Cyclone 5 + Embedded USB Blaster
Hello. I'm trying to make a board with a HDMI port connected on a Cyclone V 5CSXFC6D6F31C8NES. After some research, it appears that I could use an ADV7513 (Analog device) chip to transform...
13 years ago --- Quote Start --- As for the on board USB Blaster solution, unless you're an close ally of Altera (such as Terasic) you'll not get the code required for the CPLD in their USB Blasters. --- Quote End --- Although Thomas Entner has reverse engineered it....... http://www.entner-electronics.com/tl/index.php/eeblaster.html This also has a smaller footprint 6 pin header for the JTAG header, much better that the 0.1" pitch monstrosity we're all used to! Nial
