16 years agohaving issues while installing altpciechdma
I was trying to install altpciechdma on FC 11 64-bit. and then it shows this error?
can anybody tell why this error occurred or how to remove it.....? Thanks altpciechdma init(), built at Apr 6 2010 14:54:56 probe(dev = 0xffff88003e364000, pciid = 0xffffffffa029bd30) serial=1 probe() ape = 0xffff8800229c6e40 serial=2 sizeof(struct ape_chdma_table) = 4096. table_virt = ffff88002e932000, table_bus = 0x 2e932000. altpciechdma 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 serial=3 altpciechdma 0000:01:00.0: setting latency timer to 64 enable pci master. alloc irq_desc for 29 on cpu 0 node 0 alloc kstat_irqs on cpu 0 node 0 altpciechdma 0000:01:00.0: irq 29 for MSI/MSI-X Enabled MSI interrupting. Using a 64-bit DMA mask. IRQ pin# 1 (0=none, 1=INTA#...4=INTD#). IRQ line# 10. Succesfully requested IRQ# 29 with dev_id 0xffff8800229c6e40 BAR0 0xd0000000-0xdfffffff flags 0x00020200 BAR1 0xcffc0000-0xcfffffff flags 0x00020200 BAR2 0xcff80000-0xcffbffff flags 0x00020200 entering to the loop for mapping of bars. BAR[0] mapped at 0xffffc20021fb0000 with length 32768(/268435456). BAR[2] mapped at 0xffffc200001e4000 with length 256(/262144). before cdev after cdev b4 dma engine. dma read header. dma write header. temp values and few datas shown. bar_tests(), PAGE_SIZE = 0x1000 write_header = 0xffffc200001e4000. read_header = 0xffffc200001e4010. &write_header->w3 = 0xffffc200001e400c &read_header->w3 = 0xffffc200001e401c ape->table_virt = 0xffff88002e932000. Allocated cache-coherent DMA buffer (virtual address = ffff880021458000, bus address = 0x0000000021458000). here in else value of n after first descriptor=0 writing 0x000400ff to 0xffffc200001e4010 writing 0x00000000 to 0xffffc200001e4014 writing 0x2e932000 to 0xffffc200001e4018 Flush posted writes value of n after flush poster writes=254 Start DMA read writing 0x000000fe to 0xffffc200001e401c EPLAST = 64222 POLL FOR READ: EPLAST = 64222, n = 254 EPLAST = 15, n = 254 EPLAST = 31, n = 254 EPLAST = 47, n = 254 EPLAST = 64, n = 254 EPLAST = 80, n = 254 EPLAST = 97, n = 254 EPLAST = 113, n = 254 EPLAST = 130, n = 254 EPLAST = 146, n = 254 EPLAST = 162, n = 254 EPLAST = 179, n = 254 EPLAST = 195, n = 254 EPLAST = 212, n = 254 EPLAST = 228, n = 254 EPLAST = 244, n = 254 EPLAST = 254, n = 254 DONE# IRQs during transfer: 1 value of n inside poll for read=254 Start DMA write POLL FOR WRITE: EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 EPLAST = 64222, n = 254 [ffff880021458000] = 0x21458000 [ffff88002145a000] = 0x21458000 [ffff880021458400] = 0x21458400 [ffff88002145a400] = 0x21458400 [ffff880021458800] = 0x21458800 [ffff88002145a800] = 0x21458800 [ffff880021458c00] = 0x21458c00 [ffff88002145ac00] = 0x21458c00 [ffff880021458d00] = 0x21458d00 != [ffff88002145ad00] = 0x214594e0 ?! [ffff880021458d04] = 0x21458d04 != [ffff88002145ad04] = 0x214594e4 ?! [ffff880021458d08] = 0x21458d08 != [ffff88002145ad08] = 0x214594e8 ?! [ffff880021458d0c] = 0x21458d0c != [ffff88002145ad0c] = 0x214594ec ?! [ffff880021458d10] = 0x21458d10 != [ffff88002145ad10] = 0x214594f0 ?! [ffff880021458d14] = 0x21458d14 != [ffff88002145ad14] = 0x214594f4 ?! [ffff880021458d18] = 0x21458d18 != [ffff88002145ad18] = 0x214594f8 ?! [ffff880021458d1c] = 0x21458d1c != [ffff88002145ad1c] = 0x214594fc ?! [ffff880021458d20] = 0x21458d20 != [ffff88002145ad20] = 0x21459500 ?! ---more errors follow! not printed--- DMA loop back test FAILED. bar_tests() end, result -1 probe() successful.1 Reply
hi,
did you solve that? how?
