has anyone observed a programmer crash when S10 transceiver tile configured?
has anyone observed any Stratix 10 issues during configuration when transceiver tiles are used? Our observation is If left unused, programming will be successful.
Only 1 of 4 transceiver tiles cause this problem. When one of 4 transceiver tiles are configured even with the simplest design, it will crash the programmer at 5% with an error log. Configuring other tiles and skipping the suspect one will make configuration pass as well.
This is from new board power up checking. Only 1 device is behaving this way but before we rule out the device, does anyone know if a signal (data or clock), or power level or connection problem can cause this behavior to the programmer?
1 Reply
- YuanLi_S_Intel
Hi Eugene,
Can you check if your ref clock is supplied properly. There is a KDB for this.
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2019/why-does-the-configuration-fail-when-transceiver--pcie--hps-emif.html
Thank YOu.
