18 years agohardware processing images
I have developed an application that using NIOSII under uCOS + nichestack receives images by using UDP protocol. I have developed an image processing algorithm by using DSP Builder I know ...
18 years agoThe algorithm developped in Simulink is based on the same method used in Avalon Edge detector example from Altera. This example uses Avalon-MM.
But I don't have so much experience with Avalon and I don't see clear what will be the best for me Avalon-ST or Avalon-MM. All incoming images will be 320x240, 76800 pixels * 16 bits = 153.6Kbytes. I'm using Cyclone III NIOSII eval kit Bandwith will be 5-10 frame/s I can have 2 posibilities , 1) After receiving an image by UDP protocol (Nios+niche stack), I think I should write the image to memory (SRAM or DDR) in this case, Should I use Avalon-MM? 2) In the case that I would receive images from hardware by BT.656 parallel interface (no NIOS intervention), I think I wouldn't have to write data in external memory. Should I use Avalon-ST in this case?
