18 years agohardware architecture of af altera cyclone
hello, i have a live design evaluation board which altera cyclone on it.i have programmed a soft-core processor on that fpga.all i need to do is, write a simple programm to the processor in ord...
18 years ago --- Quote Start --- thx vizzie for the tips!! a found some header files and source files inside the files..but how to use them is another problem and it's also tough to understand the header and source files..some more there is no documentation of them...and some of the files i never saw in my life...can i attached the files in order for you to see? Regard, Bruno --- Quote End --- Hi Bruno, It really needs some experience before one starts coding the libraries. You should start with some samples in NIOS itself. I haven't done much coding either for libraries etc. I indeed regret that I would be unable to help you in this regard.
