SDavi9's avatar
SDavi9
2 months ago
GTS Transceiver Compatibility
I have implemented a GTS Ethernet Intel FPGA Hard IP to interface to an external Optical transceiver. Is this compatible with : Optical Interface: 1000BASE-SX Multi-mode (850nm) ?
  • Hello SDavi9
    Yes,  GTS Ethernet Hard IP can be used with an external 1000BASE‑SX optical transceiver, as long as you meet two conditions:
    • The external module provides standard 1G SerDes line rates (1.25 Gbps).
    • You interface through the transceiver’s standard serial differential pair (SFP/SFP+ type).
    But overall, it should be compatible.
    Pavee
    • paveetirrasrie_Altera's avatar
      Hello SDavi9,
      As I've answered to your question, I now transition this thread to community support.
      If you have a new question, feel free to open a new thread to get the support from Altera experts.
      Thank you
