AKorn9
6 years agoGreetings! How to add a "permit_cal" input to the PHY Lite IP?
I'am using Stratix10 and Quartus Prime 19.1 software. Now I try to use PHY Lite IP. Reference clock to this IP comes from a PLL. And I got an error: "The permit_cal input port of IOPLL is not connect...
Rahul_S_Intel1
6 years agoHi ,
Can you use the below workaround for the issue.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/tools/2018/error--20181--the-permitcal-input-of-iopll--downstream-pll--is-n.html?wapkw=the+permit_cal+input+port+of+iopll+is+not+connected+correctly
AKorn9
6 years agoHi RSree!
Thank you for answer. I understand it.
But PHY Lite IP has an internal PLL. And do not have permil_cal input. I can't connect the lock output from the upstream PLL to a PLL located inside the PHY Lite IP.
