15 years agoGray Code
I am a student, and my assignment is to create a gray code to bargraph design in VHDL using select signal assignment. I have been toying around with the following code, but it just doesnt seem to work.library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity gray_2_bar is
port( gray : in std_logic_vector (3 downto 0);
bar_graph : out std_logic_vector (9 downto 0));
attribute loc : string;
attribute loc of gray: signal is "P2,P3,P4,P5";
attribute loc of bar_graph: signal is "P27,P26,P25,P24,P23,P21,P20,P19,P18,P17";
end gray_2_bar;
--}} End of automatically maintained section
architecture gray2bar1 of gray_2_bar is
signal temp: std_logic_vector (3 downto 0);
begin
temp <= gray;
with temp select
bar_graph <= '0' when "0000",
<= '1' when "0001", --I am getting error on this line.
<= '2' when "0011",
<= '3' when "0010",
<= '4' when "0110",
<= '5' when "0111",
<= '6' when "0101",
<= '7' when "0100",
<= '8' when "1100",
<= '9' when "1101";
end gray2bar1;
The error is as follows: # Error: COMP96_0015: gray_2_bar.vhd : (46, 3): ';' expected.# Error: COMP96_0019: gray_2_bar.vhd : (46, 3): Keyword "end" expected.# Error: COMP96_0016: gray_2_bar.vhd : (46, 6): Design unit declaration expected. Any help would be greatly appreciated. Thanks and Best Regards Sarovar C2 Replies
Just wanted to post that I managed to figure it out
Ok well still working on it, here is ver. 2 of the code:
library IEEE; use IEEE.STD_LOGIC_1164.all; entity gray_2_bar is port( gray : in std_logic_vector (3 downto 0); bar_graph : out std_logic_vector (9 downto 0)); attribute loc : string; attribute loc of gray: signal is "P2,P3,P4,P5"; attribute loc of bar_graph: signal is "P27,P26,P25,P24,P23,P21,P20,P19,P18,P17"; end gray_2_bar; --}} End of automatically maintained section architecture gray2bar1 of gray_2_bar is signal temp: std_logic_vector (3 downto 0); begin temp <= gray; with temp select bar_graph <= "1111111110" when "0000", <= "1111111100" when "0001", --Still the same error on the same line. <= "1111111000" when "0011", <= "1111110000" when "0010", <= "1111100000" when "0110", <= "1111000000" when "0111", <= "1110000000" when "0101", <= "1100000000" when "0100", <= "1000000000" when "1100", <= "0000000000" when "1101", <= "0000000000" when others; end gray2bar1;
