15 years agoGray Code
Hi, I am a student, and my assignment is to create a gray code to bargraph design in VHDL using select signal assignment. I have been toying around with the following code, but it just doe...
15 years agoOk well still working on it, here is ver. 2 of the code:
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity gray_2_bar is
port( gray : in std_logic_vector (3 downto 0);
bar_graph : out std_logic_vector (9 downto 0));
attribute loc : string;
attribute loc of gray: signal is "P2,P3,P4,P5";
attribute loc of bar_graph: signal is "P27,P26,P25,P24,P23,P21,P20,P19,P18,P17";
end gray_2_bar;
--}} End of automatically maintained section
architecture gray2bar1 of gray_2_bar is
signal temp: std_logic_vector (3 downto 0);
begin
temp <= gray;
with temp select
bar_graph <= "1111111110" when "0000",
<= "1111111100" when "0001", --Still the same error on the same line.
<= "1111111000" when "0011",
<= "1111110000" when "0010",
<= "1111100000" when "0110",
<= "1111000000" when "0111",
<= "1110000000" when "0101",
<= "1100000000" when "0100",
<= "1000000000" when "1100",
<= "0000000000" when "1101",
<= "0000000000" when others;
end gray2bar1;
