11 years agoGPIO output on DE2_115
I have a DE2-115 board and i'm trying to do some basic functions. I want provide a high/low input using a switch on the board,and read this high/low input as output onto a GPIO pin. i.e. whenever ...
11 years agoHi Ankita,
I checked my GPIO pin with a DVM (rather than a scope). However, I'm confident it worked. If you can drive an LED directly from the same GPIO pin (that's what you tired - yes?) then you can be confident the logic level is appearing on the GPIO pin. I'm now suspecting your scope setup if that's not showing the level change. Cheers, Alex
