15 years ago
global clock buffer problems
Dear all,
Here is my code for multiplexer. I used a secondary global clock buffer (BUFGS) in the code.
library ieee;
use ieee.std_logic_1164.all;
entity clock_mux is
port (DATA, SEL : in std_logic;
SLOW_CLOCK, FAST_CLOCK : in std_logic;
DOUT : out std_logic);
end clock_mux;
architecture XILINX of clock_mux is
signal CLOCK : std_logic;
signal CLOCK_GBUF : std_logic;
component BUFGS
port (I : in std_logic;
O : out std_logic);
end component;
begin
Clock_MUX : process (SEL)
begin
if (SEL = '1') then
CLOCK<= FAST_CLOCK;
else
CLOCK<= SLOW_CLOCK;
end if;
end process;
GBUF_FOR_MUX_CLOCK : BUFGS
port map (I=> CLOCK, O=> CLOCK_GBUF);
Data_Path : process (CLOCK_GBUF, DATA)
begin
if (CLOCK_GBUF'event and CLOCK_GBUF = '1') then
DOUT<= DATA;
end if;
end process;
end XILINX;
But the error occurred after compile the code:
Error: Node instance "GBUF_FOR_MUX_CLOCK" instantiates undefined entity "BUFGS"
As i know, we need to instantiate the BUFGS by using the Insert Pads command. However, i do not clear about the Insert Pads command. Can anyone help me please.
Many thanks
    Dear rbugalho,
    It is different using BUFGS in ALTERA and XILINX?
    Many thanks for your response
    Dear DT, this forum is about Altera FPGAs, not Xilinx FPGAs.
