12 years agoGiving external input to Triple Speed Ethernet
Hello everybody, I want to modify the tutorial "using Triple Speed Ethernet" according to my requirement. In brief what I used is: Qsys(Hardware Generation), NIOS II Eclipse(ApplicationSoftware...
8 years agoYes I admit it looks strange, it seems that the TSE is waiting for something before sending the packet. But I don't see anything wrong with the way you implemented the interface.
As for your software question, are you making a baremetal application with no operating system? I'm not familiar with this setup, but if you need to be sure you could set up a breakpoint in the driver's init function and see if and when it is triggered when you run the application.
