12 years agoGiving external input to Triple Speed Ethernet
Hello everybody, I want to modify the tutorial "using Triple Speed Ethernet" according to my requirement. In brief what I used is: Qsys(Hardware Generation), NIOS II Eclipse(ApplicationSoftware...
12 years ago --- Quote Start --- If I remove this SGDMAs, where exactly I have to connect (to the avalon stream interfaces) from own IP. --- Quote End --- You would connect to the "transmit" and "receive" Avalon Streaming ports of the TSE MAC. See this page: http://www.alterawiki.com/wiki/nios_ii_udp_offload_example In that example, IP blocks are connected in addition to the SGDMA (through the packet multiplexer/demultiplexer pair). Replace the "PRBS packet generator", "UDP payload inserter", and "Alignment pad inserter" with your own IP (and same thing on the receive side, if needed). If you don't need the NIOS / SGDMA, then you probably delete the multiplexer/demultiplexer as well and connect directly to the TSE MAC.
