14 years agogigabit ethernet
For a Cyclone IV: Does Gigabit ethernet need to be implemented using transceivers, or can it be implemented using the normal IO pins? The PHY that was selected for this implementation has four separa...
14 years agoCyclones do support DDR I/O.
You should check if the FPGA supports the speeds you need with the I/O standard you need though.
