14 years agogigabit ethernet
For a Cyclone IV: Does Gigabit ethernet need to be implemented using transceivers, or can it be implemented using the normal IO pins? The PHY that was selected for this implementation has four separa...
14 years agoHi,
As you have single ended Tx and Rx then better u can choose LVCMOS,DDIO. But In Cyclone IV if the LVCMOS IO standard support 1GigE data rate, you can surely go ahead.But i am sure it will support. T&R suresha
