14 years agogigabit ethernet
For a Cyclone IV: Does Gigabit ethernet need to be implemented using transceivers, or can it be implemented using the normal IO pins? The PHY that was selected for this implementation has four separa...
14 years agoI need to implement a 1 Gige on a Cyclone IV. It looks like I can either use a transceiver to implement a serial SGMII, or use standard IO to implement an RGMII. For the RGMII implementation, it is not clear to me whether there are restrictions on what IO pins I can use to connect to the PHY.
