12 years agoGetting started with bare-metal application development with the Cyclone V
First post! Hello fellow FPGA enthusiasts. This is my first foray into the wide world of SoC development. A bit of background. I'm pretty much fresh out from University and work for a cons...
12 years agou-boot is, itself, "baremetal" code. You can build on the example apps that are shipped with u-boot and/or extend the console UI to test what you'd like to test by adding your own "cmd_" files or adding to what's already there (hint: look at the "common" subdir for examples there).
You can also make use of the HWLibs examples that are shipped with Altera's SoCEDS (@ $SOCEDS_DEST_ROOT/examples/software/Altera-SoCFPGA-HardwareLib-16550-CV-GNU.tar.gz, for example) as a starting point. HWLibs are intended to provide a common abstraction for accessing all of the peripherals (browse the source to see what's supported at this point in time or post here with what you/you'll need.) There's a description of how to import these examples into the DS-5 IDE in the SoCEDS User's Guide. You can make use of either HWLibs or u-boot as a starting point. u-boot supports more peripherals at this point in time, but may use too many of the "Linux or Linux-like" abstractions for your liking. HWLibs is designed to provide a portable, simple API to common peripherals on an SoC device. I would try both and see which you prefer. Mind you that "baremetal" usage for these cores (or any Cortex-A series) is not recommended. Do you want to (for instance) split up the two cores and run separate baremetal (while 1()) applications on each? If so, then you are "by design" throwing away a fair amount of the advantages that come with a Cortex-A class processor. I hope that helps a bit...and Good luck! slacker
