13 years agoget value from master_read_32
Hello evryone, I am trying to do a GUI interface with tcl to load the .sof that I generated into the FPGA with tcl. I want also in this tcl script read from a memory adress, get a value and p...
13 years agoHello Dave,
Thank you so much for your help. It helped me a lot but now I am stuck in something that without this I can't finish. In this procedure: proc read_button {} { global jtag # The address and data entry boxes contain only digits, # so add the leading 0x to the address set data [jtag_read 0x$jtag(address)] # and then strip the response 0x set jtag(data) [format %X $data] } I can't get the adress of the JTAG. I am using JTGA_to_Avalon_MM. Is because of this? The adress in Qsys is 0x00000000. Can you help me please? Because I am receiving this error: can't read "jtag(address)": no such element in array Kind regards
