13 years agoget value from master_read_32
Hello evryone, I am trying to do a GUI interface with tcl to load the .sof that I generated into the FPGA with tcl. I want also in this tcl script read from a memory adress, get a value and p...
13 years ago --- Quote Start --- When you write on your code JTAG it works with JTAG to Avalon Master Bridge or I need to change to other one in Qsys? --- Quote End --- You can answer this question yourself very easily by just looking at the tutorial ... which part of the block diagram on the main page of the tutorial is not clear? http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial Cheers, Dave
