get_pins
- 2 years ago
I think if you use the Keep attribute within the source code then you can use the Verilog/VHDL netnames in the sdc file. Seems to work anyhow.
Do you have any further concern or consideration on this thread?
Sheng
derive only works for PLLs
Name finder doesnt obviously indicate the source fro a clock which is generated out of a mux or logic.
Any other suggestions such as using the keep attribute in the RTL?
- sstrell2 years ago
That's what the clocks report is for. Identify what pins/ports the tool thinks are clocks and create clock constraints for them. If it's a clock that you are generating yourself, then you should know what the source should be and include it in the create_generated_clock command.
For a simple example, if you create a divide-by-two clock with a register and a feedback inverter, the clock target is the Q output of the register and the source is the D input.
- NGord2 years ago
