15 years agoGeneric shift register
I would like to create a shift register of multiple delay as depicted in the picture joined. The following code is an example with 3 registers of 8 bits.
library IEEE;
use IEEE.std_logic_1164.all;
entity ShiftRegister is
port
clock : in std_logic;
reset : in std_logic;
x0 : in std_logic_vector(7 downto 0);
x3 : out std_logic_vector(7 downto 0)
end ShiftRegister;
architecture arch_ShiftRegister of ShiftRegister is
signal x1 : std_logic_vector(7 downto 0);
signal x2 : std_logic_vector(7 downto 0);
begin
process(reset, clock)
begin
if reset = '1' then
x1 <= (others => '0');
x2 <= (others => '0');
x3 <= (others => '0');
elsif rising_edge(clock) then
x1 <= x0;
x2 <= x1;
x3 <= x2;
end if;
end process;
end architecture arch_ShiftRegister;
The problem is that in the real application, there will be about 50 registers, so I would like to avoid to copy 50 times the same lines (moreover I would like that the number of registers be configurable with a generic value). I think this is possible with the for generate instruction, but I have never use it and I am not comfortable with it. I have looked for examples in books, but I still didn't get how to use it for what I want to do. Does anybody can help and provide such code ? Thanks in advance Jérôme
