17 years agoGenerating PWM in cyclon2
Hello I am trying to write codes to generate PWM pulses in my FPGA, but it seems it does not funtion. The input "rst" reset the program but it does not synchronize with the "rst" input. Can any o...
17 years agoThanks a lot for your help. I tested the code and it has the same problem. I want the pwm output to be zero until the rst pin goes high, however now, it starts ON/OFF regardless of the rst pin :mad:
