17 years agoGenerating PWM in cyclon2
Hello I am trying to write codes to generate PWM pulses in my FPGA, but it seems it does not funtion. The input "rst" reset the program but it does not synchronize with the "rst" input. Can any o...
17 years agoHi Sameer,
don't know if my suggestions will make your system work. But please make the following changes: --- Quote Start --- entity pwm_out is port( clk : in std_logic; rst : in std_logic; loadin : in std_logic_vector(15 downto 0); pwmout : out std_logic); end entity; architecture pwm_out of pwm_out is signal cnt : std_logic_vector(16 downto 0);-- no initialization possible here, only in testbench begin process (clk) -- this is a clocked process, so "loadin" should be removed begin if (rising_edge(clk)) then if (rst = '1') then cnt <= ("0" & loadin); else if (rst = '0') then cnt <= (cnt+1); end if; end if; end if; end process; pwmout <= cnt(16); end pwm_out; --- Quote End --- The rest of your code looks good!
