16 years agoGenerating Dual Port RAM in Megawizard using Command Line
I'm trying to generate dual port ram in megawizard using command line. I would like to use dual clock with seperate "input" & "output" clocks. I use the command "qmegawiz -silent module=altsyncram -f: dualportram_params.txt mydualportram.v". dualportram_params.txt address_aclr_b=NONE address_reg_b=CLOCK0 clock_enable_input_a=BYPASS clock_enable_input_b=BYPASS clock_enable_output_b=BYPASS intended_device_family="Stratix" lpm_type=altsyncram numwords_a=32 numwords_b=32 operation_mode=DUAL_PORT outdata_aclr_b=NONE outdata_reg_b=CLOCK1 power_up_uninitialized=FALSE read_during_write_mode_mixed_ports=DONT_CARE widthad_a=5 widthad_b=5 width_a=8 width_b=8 width_byteena_a=1 clock1=used I get this error message. Error: The specified megafunction or wizard is not supported in command line mode. Parameter OUTDATA_REG_B has been assigned the value CLOCK1 which is incompatible with the current settings of ADDRESS_REG_B<CLOCK0>. The legal value is CLOCK0:UNREGISTED. I suspect my parameter lists got problem. But i don't know how to correct it? Can anyone help to correct it ??? I need to to generate dualport ram with 2 seperate input & output clocks. Appreciate anyone's help. Thanks...No RepliesBe the first to reply
