Generating an Intel Agilex per pin RLC IBIS (.ibs) file
- 2 years ago
I got update from the internal team on this request.
For your information, the IBIS Writer support for Agilex 5 is same as Agilex 7 which it has been available through script since 23.1. Customer can generate the design specific IBIS models with per pin RLC by using the script.
You may refer the Quartus Prime Pro Edition User Guide: PCB Design Tools through the link below for more info of the IBIS Writer support for the Agilex devices. As per the UG, you have to refer to the README.txt file for the complete instruction of using the script. I would recommend you use the IBIS Writer script of the latest Quartus version.
Aqid
Aqid
