13 years agoGenerating a signal with noise
What i am doing is i am trying to do is add random numbers to a signal to find PSD later. I wrote a code for random numbers generator which is working fine shown below: LIBRARY ieee; USE ie...
13 years agoHi dave i implemented division in my code but its not working as it must can you tell me if my implementation is correct or not
LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.NUMERIC_STD.ALL; --USE IEEE.NUMERIC_BIT.ALL; USE IEEE.STD_LOGIC_SIGNED.ALL; --USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY random IS ------> Interface GENERIC (n : INTEGER := 16); -- Input bit width PORT( clk : IN STD_LOGIC; random_num : OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0); x : OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0); random_mean: OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0); random_sum: OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0) ); END random; ARCHITECTURE Behavioral of random is SHARED VARIABLE sum : STD_LOGIC_VECTOR(n-1 DOWNTO 0) :=( OTHERS => '0'); SHARED VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0) := (n-1 => '1' , OTHERS => '0'); SHARED VARIABLE count,count1: STD_LOGIC_VECTOR(n-1 DOWNTO 0) :=( OTHERS => '0'); SIGNAL adi : STD_LOGIC_VECTOR(n-1 DOWNTO 0); SIGNAL sita : INTEGER RANGE 0 TO 2**n-1; SIGNAL count2,sum1 : INTEGER RANGE 0 TO 2**n-1; BEGIN PROCESS(clk) VARIABLE temp : STD_LOGIC := '0'; BEGIN IF(RISING_EDGE(clk)) THEN temp := rand_temp(n-1) XOR rand_temp(n-2); rand_temp(n-1 DOWNTO 1) := rand_temp(n-2 DOWNTO 0); rand_temp(0) := temp; END IF; random_num <= rand_temp; END PROCESS; PROCESS BEGIN WAIT UNTIL clk = '1'; sum := sum + rand_temp; count := STD_LOGIC_VECTOR(UNSIGNED(count) + 1); FOR I IN 0 TO n-1 LOOP count1(I) := count(n-1-I); END LOOP; count2 <= TO_INTEGER( UNSIGNED(count1)); sum1 <= TO_INTEGER(UNSIGNED(sum)); sita <= sum1 / count2; adi <= STD_LOGIC_VECTOR(TO_UNSIGNED(sita,16)); END PROCESS; x <= count1; random_sum <= sum; random_mean <= adi; END; Regards Adi
