14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years ago --- Quote Start --- Ok, I will switch my platform from CPLD to FPGA. And I prefer to have USB as the interface input string from laptop. Ecexpt DE0 board, what Kinds of hardware or IPs I should prepare to implement the test pattern generator? --- Quote End --- Provide a better description on what the patterns are supposed to be and we can provide a better answer. For example, do you have hundreds of individual bits/wires that you need to generate patterns on, are the patterns all the same, what frequency do you need to generate the patterns at? --- Quote Start --- My target: To have simple access to MCUs, in which, most of them are ARM based. 1. Enter some low power modes of MCUs 2. Access to their embflash memory, however, simple access would be enough. --- Quote End --- The ARM MCUs already come with these features, why do you need an FPGA? Cheers, Dave
