14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years ago --- Quote Start --- Chris, 1. It might be hundreds of bits for a input string. --- Quote End --- Then you definitely need a FPGA. --- Quote Start --- 2. Is it must to use external controls (push buttons, PLC or MCU outputs)? Can I input the string simply from the master (laptop)? --- Quote End --- Using buttons or generic I/Os was only an idea for a very simple solution. Sure you can do it with a laptop! For example you can send the pattern and control the generator with the RS232 serial port. The jtag interface solution suggested by Dave is also good, but this can be used if you only need the pattern generator connected to your laptop. If you plan to deploy the design in a commercial board, you must provide a standard widely used interface: in this case, besides RS232 you can implement virtually everything with fpga, from PCI to Ethernet, USB and so on.
