14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years ago --- Quote Start --- You must specify what do you mean for medium size: tens of bits, hundreds, thousands? The optimal solution is different in these cases. I dare say that for a pattern less than 100bits long which needs to be changed occasionally you can simply use a CPLD and the shift register solution. Usually the shift register blocks (I refer now to lpm_shiftreg) have a LOAD input which loads all data from a parallel port and/or a SHIFTIN input to load serially. For each clock edge, stored data is sent serially out of a SHIFTOUT port, and this is the pattern you want to generate. Parallel load is not convenient in your case; discard it and connect all other shiftreg input ports to external controls (push buttons, PLC or microcontroller outputs): you can do everything with these few signals. PLease note that minimal extra logic inside CPLD may be required if you need the pattern to be generated under particular conditions. --- Quote End --- Chris, 1. It might be hundreds of bits for a input string. 2. Is it must to use external controls (push buttons, PLC or MCU outputs)? Can I input the string simply from the master (laptop)? Thanks!
