14 years agoGenerate patterns through CPLD(MAXII)?
I'm new to FPGA/CPLD. Could any one help me? I'm wondering if I can use CPLD/FPGA to generate some patterns to output pins? This is for some simple test purpose. For example, under 50MHz clo...
14 years agoHow long is the pattern you need to generate?
Is a fixed pattern or do you need to change it? In the simplest cases a CPLD would be enough: I mean if you have a medium-short fixed pattern or a well defined set of short patterns. The more complex is the pattern generator, the bigger the device you'll need. I'd suggest a device like EP3C16F484 or similar range if you want a generator with a lot of features, possibly controlled through Ethernet or serial port. If you instead need only a simple push-button-and-generate-pattern device, stick on a CPLD.
