17 years agogenerate clock with pll
Hi, I'd like to know how to generate a clock with the PLL to obtain two frequencies 8kHz and 256khz and simulate with ModelSim altera in cpld.thanks
17 years agoWhat is it exactly you are after?
Do you need help using Quartus/Altera FPGAs? Do you need more info on clock dividers? The link I posted does have some Verilog code and I thought it gave a good introduction. Do you want someone to code the VHDL/verilog etc for you? It would be far better to read up on the subject and do the design and code it yourself. You'd learn a lot more and it might be fun :) Sorry to be a bit blunt but I am not sure what you are after.
