13 years agoGeneral questions about memories, configuration and FPGA systems.
Hi, I have done some research on the forum about the topic, but i have still some questions and want to verify and sum up everything. In my questions about system configuration i will refer to ...
13 years ago --- Quote Start --- It is also worth pointing out that all read cycles done by the nios cpu assert all 4 byte enables, the unwanted bytes are discarded internally. Write cycles will assert the 'correct' byte enables. However if a byte write is done to an 8-bit slave the 'fabric' will always generate 4 write cycles - 3 of which will have the (single) byte enable inactive. --- Quote End --- Hi Dsl, I don't really understand those memory byte enables. If i wanted to use memory with 16-bits i could really simply tie those to correct values and never use them again ? If i wanted to use the memory with 8-bit data i could use those byte enables to: 1. Select the lower byte - write the data at address 0 2. Select the higher byte - tie the data at address 0 3. Select the lower byte - write the data at address 1 4. Select the higher byte - tie the data at address 1 So it would effectively change the memory organization. But those byte enables are only masks, as i suppose they are only for the reason to not change the higher/lower word when connecting with 16-bit data line. Are normal memory controllers for 8-bit 'fabric' chips as you say, able to use effectively 16-bit memory ? Because those byte enables are only for masking data. When connecting 8 bits to D[0..7] of memory i'm able to write only to lower bytes. Those bytes enables normally are not for routing the data internally in memory chip. So when connecting to 8-bit to 16-bit memory those bytes enables really doesn't matter, right? Are there any other usage for byte enables? The same concept would be in DDR memories? best regards, madness
