14 years agoGated dedicated clock outputs
I'm currently not understanding an issue that turns up with my Stratix III EP3SL50 Device. what i try to do: In a PLL (altpll) I generate a 70 MHz clock from a 50 MHz clock. The resultin...
14 years agoIt aligns the clock with the output data in case of a source synchronous output bus. In a source synchronous output it would be disadvantageous to have the output clock come from the dedicated PLL output pins as the timing (over the PVT range) is quite different.
