16 years agogate timing spec on 40nm FPGA
Hi everybody, Does anyone know what is the delay time of a "not" gate in 40nm technology? And does anyone know what is the minimum pulse width for clock input in one FlipFlop or in one D-latc...
16 years agoShalom,
To achieve phase shift between clocks, the best option is to use the PLL in the Altera megafucntion library. You can easily configure it to implement a phase shift between the different clock outputs. Have a look at it and let us know if it will do the job for you. It´s quite simple to understand and configure.
