10 years agogate level simulation error
Hi all, i have a problem in gate level simulation. actually i have two kits 1- cyclone IV gx EP4CGX150DF31C7 kit 2- SDALTEVK (ti) sdi kit. both kits can be connected through HSMC, duri...
10 years agoHI Alex,
this for your ans, it really works for me. after this i have new error while programming file generation. Internal Error: Sub-system: ASMDB, File: /quartus/db/asmdb/asmdb_mux.cpp, Line: 363 ASMDB_MUX error: ENCODED_MUX::select : index out of range (index = 16, size = 16) : last archgroup encountered: type = PLL_VOLTAGE_REGULATOR_STINGRAY, block_type = GENERAL_PLL Stack Trace: 0x2826a: ASMDB_MUX::internal_error + 0x83a (db_asmdb) 0x28611: ASMDB_ENCODED_MUX::select + 0x61 (db_asmdb) 0x13a33: ASMDB_ARCH_GROUP_STD::select + 0x153 (db_asmdb) 0x1e578: ASM_ARCH_GROUP::mux_select + 0xd8 (comp_asmcc) 0x1289d8: ASM_LAB_BITS::get_row_size + 0x9e08 (comp_asm) 0x20577f: ASM_AVALON_SPACE::operator= + 0x121f (comp_asm) 0x207444: asm_process_sof + 0xb04 (comp_asm) 0x20a511: asm_process_sof + 0x3bd1 (comp_asm) 0x20d451: asm_assemble + 0x3e1 (comp_asm) 0x12718: QEXE_ARGS::get_command_line + 0x1ca8 (comp_qexe) 0x15a7a: qexe_process_cmdline_arguments + 0x5aa (comp_qexe) 0x15b91: qexe_standard_main + 0xa1 (comp_qexe) 0x4e88: msg_exe_fini + 0x58 (CCL_MSG) 0x56cc: msg_exe_fini + 0x89c (CCL_MSG) 0x1614: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x1a4 (ccl_mem) 0x62ff: msg_exe_main + 0x8f (CCL_MSG) 0x1652c: BaseThreadInitThunk + 0xc (kernel32) 0x2c520: RtlUserThreadStart + 0x20 (ntdll) End-trace Quartus II 64-Bit Version 12.1 Build 243 01/31/2013 SJ Web Edition Service Pack Installed: 1 what i do for this ??
