13 years agofwrite and UART RXData
I need some help. My Matlab code is as follows: fopen(s); fwrite(s,127,'int8'); A=fscanf(s,'%i'); B=fscanf(s,'%i'); B=fscanf(s,'%i'); fwrite(s,127,'int8'); fclose(s); However, when I try to perform a printf from Nios2, all I recieved was the the value from the first fwrite(...). The data from the second fwrite(...) seems to be missing. Why this is so? Thanks.1 Reply
Hi, with only those elements, hard to help you.
To be clear : { PC -------------to, via serial interface (RS232...),----------------> your NIOS II board } Here you posted the Matlab "program" that sends data from your PC. { your NIOS II board ---------- to, via JTAG--------------> your PC or another PC } Your NIOS II receive data and you use "printf" to print, via JTAG, to your Nios II terminal Right ? How does your NIOS II program look like ? With NIOS II, You use interrupts or simply read RS232 time to time ?
