14 years agofunctional simulation + STA = gate level simulation?
Hi: Is "functional simulation" + "STA" = "gate level simulation"? I designed a project,and run the functional simulation successfully,at the same time,the timequest timing analysis has no warnin...
14 years agoI usually also go directly from RTL to FPGA testing, when TimeQuest gives the green flag.
That said, there are a few caveats to keep in mind. - You may have gotten your constraints wrong. - There may be subtle inconsistenties between what you describe in HDL and what the synthesis tool produces. Consider this trivial piece of VHDL when x is 'X' y <= '1' when x = '1' else '0'; In RTL simulation, y will become '0'; post synthesis, y will become 'X'. I don't recall ever coming across trouble with this when designing for FPGAs, only for ASICs. Best beware. - There may be bugs/limitations in the synthesis tools and STA tools. Ie, once upon a time in an old design, TimeQuest was missing a timing failure in totally normal register to register transfer in the same clock. But the bug showed up in gate level simulation (and in the FPGA). PS: I have a very degree of confidence in TimeQuest. Don't want to start any flame war but I would not extend the same degree of confidence to lesser STA tools such as Altera's Classical Timing Analyzer or Xilinx's TRACE.
