15 years agoFull adder vhdl
Hi, I am very new to VHDL and I am struggling with errors.
I am trying to design a FULLADDER and to use it to design a Wallace Tree technique. My first question is do anyone know how to combine, to use full adder to get a wallace Tree? In the code below I've started to design a full adder, but I've an error : Error (10500): VHDL syntax error at test.vhd(23) near text "signal"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration" Library ieee; --import library use ieee.std_logic_1164.all; package WTree is component FullAdder port( in1,in2,in3: in std_logic; o1,o2: out std_logic); end component; end package; Library ieee; --import library use ieee.std_logic_1164.all; Library work; --import library use work.WTree.all; entity test is port( in1,in2,in3: in std_logic; o1,o2: out std_logic); end entity; signal D1,CO1: std_logic; architecture WallaceT of test is --For U1: FullAdder use entity work.test(WallaceT); begin U1: FullAdder port map(in1,in2,in3,o1=>D1,o2=>CO1); o1 <= in1 xor in2 xor in3; o2 <= (in1 and in2) or (in2 and in3) or (in3 and in1); end architecture; Thank You in advanceNo RepliesBe the first to reply
