13 years agoFTDI FT2232H Sync FIFO + FPGA
Hi guys, I'm using Morph-IC II and i'm having problems establishing the usb-communication between my Cyclone 2 and the FTDI FT2232H. My objective is to send a start/reset signal from PC->...
10 years agoHello Michele
Have you seen http://electro-logic.blogspot.it/2014/03/fpga-comunicazione-ad-alta-velocita_99.html?m=1 (http://electro-logic.blogspot.it/2014/03/fpga-comunicazione-ad-alta-velocita_99.html?m=1)? Ciao! --- Quote Start --- Dear Dave Hawkins, let me first introduce myself. I am Michele Ricci, a master degree student in electronic engineering at Politecnico di MIlano. I am currently working on my master thesis and one of my tasks is to interface a spartan6 with a FT232H chip in a 245 synchronous style.I am wondering if you mind sharing with me your vhdl/verilog code for the communication (basically the blocks described at page 24 of your notes), that could really make my work easier and, most of all, faster. Thank you in advance if you accept to do this, if not i must however thank you for the notes , wich i' ve found extremely detailed and clear. Best Regards, MIchele Ricci --- Quote End ---
