13 years agoFTDI FT2232H Sync FIFO + FPGA
Hi guys, I'm using Morph-IC II and i'm having problems establishing the usb-communication between my Cyclone 2 and the FTDI FT2232H. My objective is to send a start/reset signal from PC->...
11 years agoHi Dave -
Is it possible you can share your VHDL/Verilog code for UM232H Synchronous FIFO mode. Basically the blocks in FTDI Synchronous FIFO mode to Avalon-ST Bridge diagram ? I just want to use those blocks for interfacing an FPGA for data transfer. Thanks JP --- Quote Start --- Hi Günther, Excellent! The FTDI to Avalon-MM bridge performance would be much higher using a binary protocol like that used with the JTAG-to-Avalon-MM bridge ... https://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf https://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.zip But I haven't gotten around to writing that code ... Cheers, Dave --- Quote End ---
