13 years agoFTDI FT2232H Sync FIFO + FPGA
Hi guys, I'm using Morph-IC II and i'm having problems establishing the usb-communication between my Cyclone 2 and the FTDI FT2232H. My objective is to send a start/reset signal from PC->...
11 years agoHi Günther,
--- Quote Start --- I got it working eventually. The design you sent me was for the asynchronous mode, but using the existing IP and your documentation, I could get the synchronous mode working as well. --- Quote End --- Excellent! The FTDI to Avalon-MM bridge performance would be much higher using a binary protocol like that used with the JTAG-to-Avalon-MM bridge ... https://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf https://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.zip But I haven't gotten around to writing that code ... Cheers, Dave
