17 years agoFSM design/reset
Hi! I'm currently implementing some control logic using an FSM on a Stratix II chip. I'm having issues writing a "clean" FSM design, as I don't have an external reset signal available. My questions a...
17 years agoHi,
You can generate internal reset for whatever purpose after power up or any time by using basic logic or a small counter. signal count : unsigned(3 downto 0); -- to prevent compiler optimising away count attribute keep_count:boolean; attribute keep_count of count :signal is true; process begin wait until clk = '1'; if count < 15 then count <= count + 1; end if; if count < 10 then reset <= '1'; else reset <= '0'; end if; end process; edit: To be on safe side you may also add keep attribute to reset, also make sure that the (power-up don't care) is off so that the count starts at 0 always.
