15 years agofsm debuging
fsm debugging Hi I started to check the fsm on real time and got some strange behaviors. I tried working with SignalTap but I didn't like the way he display the waves and we didn't really get ho...
15 years agoI have a problem implamenting your idea of matching pipeline
PwmReg: process (Clk,Rst)
begin
if (Rst='0') then
Counter <= (others=>'0');
Pwm <='0';
elsif rising_edge(Clk) then
if (Enable='1') then
if (Counter = duty_cycle) then
Counter <= (others => '0');
else
Counter <= Counter + 1;
end if;
if (pulse_length > Counter) then
Pwm <= '1';
else
Pwm <= '0';
end if;
end if;
end if;
end process PwmReg; the max number of cycles int the pwm is 100000 so if I am going for pipeline length match should I enter a delay in the fsm for 100000 cycles... I want the signals from the component to come out to the device while they genrated not after a 100000 cycles delay as you can see in the next part of the fsm code I am waiting in the same state untill I am geting the encoder approval that will come after the pwm reg finishing his count and start turnnig the servo untill the wanted distance
when execute_st =>
state_number1 <= 5;
state_number2 <= 1;
if (S_FSM_M_E_CEn = bit_high) and (S_FSM_M_E_En = bit_high) and (S_FSM_M_P_CEn = bit_high) and (S_FSM_M_P_En = bit_high) then
M_P_En <= bit_high;
M_E_En <= bit_high;
if (S_M_E_done = bit_high) then
S_FSM_M_P_pulse_length <= neutral_cycle;
next_st := stop_st;
else
next_st := execute_st;
end if;
elsif (S_FSM_M_E_CEn = bit_low) and (S_FSM_M_E_En = bit_low) and (S_FSM_M_P_CEn = bit_low) and (S_FSM_M_P_En = bit_low) then
next_st := stop_st;
else
end if; as for the idea with the flags I also having poblems because the pwm signal from the component is going through the fsm design out to the motor so where will I put the flags... for every pwm signal change I will rise a flag and then in the fsm design I will control the servo with a different signal?
