16 years agoFrom FPGA to Monitor
Hi, Im wondering if it possible to store some pictures file in the FPGA and having them loaded to the monitor screen? If yes, how do I do that? thank you very much! =)
16 years ago --- Quote Start --- If you are using Altera FPGA the onchip-memory can be initialised by a hex file, you can configure that option in the SOPC-Builder settings of the module. If you generate yourself a compatible hex-file then you can have a picture in the FPGA right from the start. (works fine for 640x480 here, I scale it in the ouputchain afterwards) Good luck! --- Quote End --- Thanks for the reply. Im not too sure.. can you give me a detail description on how can it be done?
