16 years agofrequency divider
i want ot create frequency divider which devide the frequency by 50 000 000 (so with 50 MHz clock i want ot reach 1 HZ (T=1s)) can i use this code:
library ieee;
use ieee.std_logic_116...
16 years ago
process(CLK, RST) begin
if RST then
QL <= "11101110011010110010100000000";
devided_clk<= '0';
elseif (CLK'event and CLK = '1') then
if QL == "00000000000000000" then // comparison with zero is cheaper
QL <= "11101110011010110010100000000"; // half count reached, reload
devided_clk <= ~devided_clk; // toggle output
else
QL <= QL - 1; // decrement instead of increment
end if;
end if;
end process;
This code is better and simpler. Oh, and do not forget Altera likes async resets (unlike Xilinx). But you should sync the reset signal (it should be the output of a CLK clocked register).
