13 years agoFrame Buffer VHDL Template
Hello every body, I'm trying to code a frame buffer using VHDL to perform some operation on an entire frame then store the result into DDR2 memory. I used the Avalon MM Master VHDL Template b...
13 years agoHi and thank you for responding.
I used the Avalon MM Master VHDL template and a custom core that enable the master when there is a valid data: a simple Avalon ST Interface which enables the master using this code :
PROCESS (CLOCK,RESET)
IF CLOCK'EVENT AND CLOCK='1' THEN
IF AST_DIN_VALID = '1' THEN
IF AST_DIN_SOP = '0' AND AST_DIN_EOP = '0' THEN
ENABLE = '1';
ELSE
ENABLE = '0';
END IF;
END IF;
END IF;
END PROCESS;
PROCESS (CLOCK,ENABLE)
BEGIN
IF ENABLE = '1' THEN
--START the master:
avs_csr_write <= '1';
avs_csr_address <= "00";
avs_csr_writedata <= "00000000000000000000000000000001";
DATA_To_Write <= AST_DIN_DATA;
ELSE
avs_csr_write <= '0';
avs_csr_writedata <= (others => '0');
DATA_To_Write <= (others => '0');
END IF;
END PROCESS;
and the master template : library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity simple_example is
port (
-- clock interface
csi_clock_clk : in std_logic;
csi_clock_reset : in std_logic;
-- read master
avm_read_master_read : out std_logic;
avm_read_master_address : out std_logic_vector (31 downto 0);
avm_read_master_readdata : in std_logic_vector (31 downto 0);
avm_read_master_waitrequest : in std_logic;
-- write master
avm_write_master_write : out std_logic;
avm_write_master_address : out std_logic_vector (31 downto 0);
avm_write_master_writedata : out std_logic_vector (31 downto 0);
avm_write_master_waitrequest : in std_logic;
-- control & status registers (CSR) slave
avs_csr_address : in std_logic_vector (1 downto 0);
avs_csr_readdata : out std_logic_vector (31 downto 0);
avs_csr_write : in std_logic;
avs_csr_writedata : in std_logic_vector (31 downto 0)
end simple_example;
architecture a of simple_example is
-- the FIFO component was generated using the Quartus II MegaWizard Plug-In Manager
component example_master_fifo
port (
aclr : in std_logic;
clock : in std_logic;
rdreq : in std_logic;
wrreq : in std_logic;
empty : out std_logic;
full : out std_logic;
q : out std_logic_vector (31 downto 0);
usedw : out std_logic_vector (5 downto 0)
end component;
-- fifo instantiation signals
signal fifo_read, fifo_write : std_logic;
signal fifo_empty, fifo_full : std_logic;
-- state machine states
type read_states_T is (idle, running, stopping);
type write_states_T is (idle, running);
signal read_state : read_states_T;
signal write_state : write_states_T;
-- extra read master signals
signal read_address : std_logic_vector (31 downto 0); -- the current read address
signal words_read : std_logic_vector (8 downto 0); -- tracks the words read
-- extra write master signals
signal write_address : std_logic_vector (31 downto 0); -- the current write address
-- CSR registers
signal csr_status : std_logic_vector (31 downto 0); -- the status word that will be read from the status register
signal csr_rd_addr : std_logic_vector (31 downto 0); -- the read start address register
signal csr_wr_addr : std_logic_vector (31 downto 0); -- the write start address register
signal csr_go_flag : std_logic; -- used to start the DMA (when logic 1)
signal active_flag : std_logic; -- logic 1 if either state machines are active
begin
-- FIFO INSTATIATION
fifo_inst: example_master_fifo
port map (
aclr => csi_clock_reset,
clock => csi_clock_clk,
data => avm_read_master_readdata,
rdreq => fifo_read,
wrreq => fifo_write,
empty => fifo_empty,
full => fifo_full,
q => avm_write_master_writedata,
usedw => open
read_FSM: process (csi_clock_clk, csi_clock_reset)
begin
if csi_clock_reset = '1' then
read_state <= idle;
read_address <= (others => '0');
words_read <= (others => '0');
elsif rising_edge (csi_clock_clk) then
case read_state is
-- IDLE
-- When idle just sit and wait for the go flag.
-- Only start if the write state machine is idle as it may be
-- finishing a previous data transfer.
-- Start the machine by moving to the running state and initialising address and counters.
when idle =>
if write_state = idle and csr_go_flag = '1' then
read_state <= running;
read_address <= csr_rd_addr;
end if;
-- RUNNING
-- Count reads, inc address and check for completion
-- The read signal is held inactive by comb logic if fifo full so do nothing if fifo full
-- also do nothing if waitrequest is active as this means signals need to be held
when running =>
-- if waitrequest is active or fifo full do nothing, otherwise...
if avm_read_master_waitrequest /= '1' and fifo_full /= '1' then
read_address <= read_address + 4; -- add 4 per word as masters use byte addressing
words_read <= words_read + 1;
if words_read = 255 then -- 256 in total (255 previous plus this one)
read_state <= stopping;
end if;
end if;
when stopping =>
read_state <= idle;
end case;
end if;
end process;
-- read when in in running state and fifo not full
avm_read_master_read <= '1' when read_state = running and fifo_full = '0' else '0';
-- simply write data into the fifo as it comes in (read asserted and waitrequest not active)
fifo_write <= '1' when read_state = running and avm_read_master_waitrequest = '0' and fifo_full = '0' else '0';
-- this maps the internal address directly to the external port
avm_read_master_address <= read_address;
write_FSM: process (csi_clock_clk, csi_clock_reset)
begin
write_state <= idle;
case write_state is
-- IDLE
-- Just sit and wait for the go flag
-- When the go flag is set start by moving to the writing state and
-- set the address.
when idle =>
if csr_go_flag = '1' then
write_state <= running;
write_address <= csr_wr_addr;
end if;
when running =>
if avm_write_master_waitrequest /= '1' and fifo_empty /= '1' then
write_address <= write_address + 4; -- Masters use byte addressing so inc by 4 for next word
end if;
if fifo_empty = '1' and read_state = idle then
end if;
end case;
end if;
end process;
-- the write signal is active if in running state and fifo not empty
avm_write_master_write <= '1' when write_state = running and fifo_empty = '0' else '0';
avm_write_master_address <= write_address;
-- the fifo_read signal takes data from the fifo and updates it's output with the next word
-- should be 1 when writing and not in waitrequest
fifo_read <= '1' when write_state = running and fifo_empty = '0' and avm_write_master_waitrequest = '0' else '0';
-- control and status registers
-- address map
-- 00 control (write only)
-- 01 status (read only)
-- 10 read start address
-- 11 write start address
-- control register
-- bit 0 : start control (pulse 1 to start)
-- status register
-- bit 0 : active flag (1 when DMA active)
-- write control of read and write address registers
csr: process (csi_clock_clk, csi_clock_reset)
begin
csr_rd_addr <= (others => '0');
csr_wr_addr <= (others => '0');
if avs_csr_write = '1' then
case avs_csr_address is
when "10" =>
csr_rd_addr <= avs_csr_writedata (31 downto 2) & "00";
-- ignore 2 lsbs as this component only supports word aligned data
when "11" =>
csr_wr_addr <= avs_csr_writedata (31 downto 2) & "00";
when others =>
end case;
end if;
end if;
end process;
csr_go_flag <= avs_csr_writedata(0) when avs_csr_write = '1' and avs_csr_address = "00" else '0';
-- readdata mux
active_flag <= '0' when read_state = idle and write_state = idle else '1';
csr_status <= "0000000000000000000000000000000" & active_flag;
read_mux: process (avs_csr_address, csr_status, csr_rd_addr, csr_wr_addr)
begin
when "10" =>
avs_csr_readdata <= csr_rd_addr;
when "11" =>
avs_csr_readdata <= csr_wr_addr;
when others =>
avs_csr_readdata <= csr_status;
end case;
end process;
end a; I don't knwo what's wrong ! I actually can't tell what data is written in the memory ! I don't know how to map the DATA_To_Write signal because I can't figure out what data is written to the memory ! Thank you.
