8 years agoFPP Configuration, Bank 2A and reuse
Is it possible to reuse configuration pins (e.g. FPP) during User Mode? We have a 16-bit parallel bus to FPP-configure the FPGA from a Host and want to reuse the same 16-bit bus during User Mode (for...
8 years agoHello Alex, thank you for your positive response. Correct, the FPGA will be operated as a memory-mapped peripheral by the Host in User Mode.
Even if the Guideline should refer only to the hosting of external memory from the FPGA, I agree that also in this case the Guideline is perplexing, and it does seem quite adamant. Would it be possible to clarify this with the design team, perhaps?
